Help, can't change my Weather icon!
Jul 9, 2007
Hi all, for some strange reason, i can't change my weather icon at all. I have tried everything but it's stuck with the old "23 degree" icon. Repring, reboot, moved it on a different page, replaced icon in app folder, summerboard fold, nothing! Funny thing is when i go to "poof" it, i see the "73 degree" icon instead. I put in in my category sub folder that i had made, and the weather icon i want shows up. Any idea as to what happened and if i can fix it? Thanks.
themanofthedark
Jan 5, 2008
2,674
26
Boston
you need to change your regional settings to US
because most SMB themes, they replace only the 73 icon.
Jul 9, 2007
Thank you so much. It was driving me insane. Very weird glitch. Don't know how that happened but i did as you said it it WORKED! Thank you again.
