Help creating ringtone in iTunes
xemanx
Sep 12, 2007
Hey is anyone else having this problem when i go to create a ringtone the "Buy" button after you select what portion of the song you want to use is not there the only 2 buttons that show up are the preview button and the loop time button it appears there are supposed to be two additonal buttons there but they are not and you cannot scrool over so... you are unable to create a ringtone. Any help would be appreciated
Thanks!
First of all, periods are your friend. I had to read that 3 times to comprehend it.
Second, try these things:
1) Quit and Restart iTunes, reinstall it if necessary. (You will not loose any songs.)
2) Make sure the song you are using is Ringtone compatible
3) Cancel the ringtone and try it again.
Hope this helps.
