Help, Digital Copy
XedgeXios666
Oct 30, 2011
I synced my digital copy to my iTunes on my pc.. I try to sync to my iPhone 4. It says movie cannot be played on this iPhone.. Why?! :( HELP
Rugaby
Feb 18, 2011
7,122
1,172
Washington state
Have you ever. Been able to sync a digital copy to your phone before?
Could be a copyright error of some sort. Happens with music a lot that isn't purchased through iTunes.
Try running it through another program first then to iTunes. Try handbrake.
XedgeXios666
Oct 30, 2011
No. And I also can't even play it on the computer.. It says this iTunes does not have Quiktime. I dnt know crap lol I jus want my movie on my phone. I pay extra to have digi copy n I hVe trouble:( sux
kimo
Aug 7, 2007
169
What OS and how many bit 32 or 64 is your computer using? Also where did the digital copy come from?
kimo
Aug 7, 2007
169
What operating system is your computer using? go to your control panel of your computer and double click system.
kimo
Aug 7, 2007
169
Then you use iTunes 64 bit, Use google on how to backup you iTunes media folder. uninstall iTunes, reinstall iTunes with iTunes running under file in iTunes use add folder to Library on your backup iTunes media folder. If you need more info on this google hoe to reinstall iTunes. Also Quicktime is another program from Apple to play movies in iTunes.
cjmorris
May 6, 2012
Ellijay, Georgia
ok i have the same problem as above but after i downloaded quicktime i still cant get the movie on my iPhone. i ahev been fighting with this for weeks please help
kimo
Aug 7, 2007
169
Start iTunes, connect your iPhone by USB cable. Once iTunes recognizes your iPhone, click on your phone (left side column) select the Movies tab. Check sync movies and select the movies that you may have gotten a digital file in 264h format and is displayed in iTunes. Any other movie files you will need to google on hoe to convert them to 264h and adding them to iTunes.
Watcher
Mar 29, 2009
1,785
30
Phoenix, AZ
I was going to say, doesn't iTunes now install Quicktime along with iTunes? I thought it's been that way for a while.
