HELP! Erased Contents and settings
Zelluca
Mar 18, 2009
Hi All,
I had to erase all contents and settings from my iPhone 3G (I did by mistake,I should have just restored it with iTunes I know...now!)
After waiting a long hour and so, the phone had the Apple icon on and off for a while...I was able to put the phone in DFU mode, once I reset it, iTunes says the sim card is not valid, and on the screen on the phone I am only allowed emergency calls.
I am using a Turbo sim in it with Tmobile, the weird thing is that I have signal adn I can also receive phonecalls!
How do I get my phone to normal?
Thanks a lot!
Adam1389
Nov 20, 2008
588
Ilwaco, WA
I'm guessing its unlocked if you are using it on t-mobile..I think you can only do a restore with an AT&T sim card. Or maybe try with out the card and see what happens.
icecreamman2
Jul 23, 2008
207
san francisco/vancouver
You can only activate the iPhone with it's lo led provider, try to find a friend with AT&T and activate with there sim card then pop yours in
