Help fixing iPod/iTunes function with iPhone!
Bud8brian
May 4, 2008
I have a jailbroken iPhone running firmware 1.1.4 right now. I have installer on it and have downloaded some different apps. Last night I got around to getting the NES and SNES emulator on my phone and followed some online instructions on how to add games to them. This went fine and I now have games loaded on each emulator. Only problem is at some point this caused my ipod function and iTunes on the iPhone to become disabled. When I touch the ipod key or iTunes key on my iPhone it just comes up with a blank screen and backs right out of it. iTunes software on my computer does not recognize the iPhone at all, but it does come up when the phone is connected to the USB port. Drivers in windows are working fine. By the way I used Winscp to add the games to the emulators. I checked my free space on the iPhone and I have 7.1GB available out of a possible 7.3GB. So obviously iTunes is gone. I had about 1250 songs on there, it is backed up in my iTunes software as of 9:32 pm last evening. Can anyone help? Contact me through here or my email is bud8brian@sbcglobal.net
Brian
The iPod and iTunes applications issue on the iPhone sounds like a permissions issue. Install MobileFinder and navigate the these applications, which are located in /Applications. Select them, and tap 'Modify' at the bottom. Look around for permissions and tell me what you find.
As for the issue with the iPhone not being recognized, try using a different USB port and reinstalling iTunes.
- John
Bud8brian
May 4, 2008
- John
I installed MobileFinder and the permissions under both Ipod/iTunes is 509. Not sure what that means.
