Help Help Help !
erfan
Nov 21, 2007
88
yesterday i had a problem that my clock section of the phone didn't work .. so to the advice of some members i upgraded it by learning from a video .. i downlgraded to 1.1.1 and than to 1,1,2 now .. it says that INCORECT SIM INSERT AN UNLOCKED AND VALID SIM TO ACTIVATE iPhone
when i got this phone it was alredy unlocked and i just put my sim card in it and it worked .. now i have a problem .. can please anyone help
oh and it gave this error since the beginning of the prosidure .. please help please !
maf2003
Sep 24, 2007
26
im guessing you got the phone with unlock 1.1.2 bc u said u downgraded to 1.1.1. before you went from 1.1.1 to 1.1.2 did you install Oktoprep? and when you got to 1.1.2 did you use 1.1.2 jailbreak?
maf2003
Sep 24, 2007
26
so you upgraded to 1.1.2. what happen when you try to use 1.1.2 jailbreak?
you could do is
put phone in DFU mode
restore back to 1.1.1, you will get an error(and kick it out of DFU mode with 1.1.2 jailbreak)
and use jailbreakme.com
remember to put autolock to never
using installer, install baseband downgrader to downgrader back to 3.14.xx
baseband
(DFU mode) restore back to 1.1.1 to get a clean 1.1.1.
after that use jailbreakme.com again
install Oktoprep
(don't put in DFU mode just connect to iTunes) UPGRADE to 1.1.2.
use 1.1.2jailbreak
then install anysim1.2.1u
put phone to aireplane mode
run anysim1.2.1u
*fix guide. don't put phone in DFU mode when u going to 1.1.1 to 1.1.2. when you connect to iTunes it will find it and and you can upgrade to it. remember to always use the shift+upgrade/restore trick to use your own firmware file and have to download it from iTunes*
Ive done this to my phone when my phone was acting up. it takes about a hour or so.
erfan
Nov 21, 2007
88
ah... sorry but now i recovered to 1.1.2 ... n i cant do anything .. how can it change to DFU mode ? and now i am restoring again .. i ll let u know what happens tell me how to change the mode to DFU
maf2003
Sep 24, 2007
26
well to put phone in DFU mode(restore mode) having the phone off. hold sleep/power button and the home button together. the phone will turn on and once the screen goes blank let go of sleep/power button while still holding home button then just connect phone to PC/Mac and iTunes will recognize phone in restore mode(DFU mode). don't let go of home button until iTunes shows it recognize it. then you can shift+restore and point to your firmware file. if you restore again to 1.1.2 then it wont work. restoring will erase Oktoprep. thats why you need to upgrade to 1.1.2 and not restore.
I made the mistake to put DFU mode when upgrading to 1.1.2 on my guide. i fix it on my post of instructions.
maf2003
Sep 24, 2007
26
if you have the 1.1.1 firmware file on your computer just put phone in DFU mode and Restore to 1.1.1 using the shift+restore trick and point to 1.1.1 firmware file. at the end of the restore mode you will get an error 1605(i think) its ok. run the 1.1.2 jailbreak and there is a second button says to kick phone out of restore(DFU) mode. then use the jailbreakme.com then tell me when you get there
maf2003
Sep 24, 2007
26
so now you should be sitting on a jailbroken 1.1.1.
i hope you have wifi :D forgot about u needed it.
if you do then
1) put autolock to never
2) using installer, install baseband downgrader to downgrader back to 3.14.xx
baseband
3) (DFU mode) restore back to 1.1.1 to get a clean 1.1.1.
4) after that use jailbreakme.com again
5) install Oktoprep
use 1.1.2jailbreak
6) then install anysim1.2.1u
7) put phone to aireplane mode ( don't forget or it will fail)
8) put autolock to never
9) run anysim1.2.1u
erfan
Nov 21, 2007
88
i searched baseband downlgrade but didn't find it .. so i jst went with it and now i am at 1.1.2 and i am going to use jailbreaker now and see what happens .. so this is what i did..
I downgraded to 1.1.1 and than made that call thingi and put it to never and than i went to jailbreakme.com and install that crap .. and than i pressed cntr+upgread and i put 1.1.2 and now i am going to jail break it ..
erfan
Nov 21, 2007
88
man do you know anything about 1.1.3 .. because now when i was doing all this it writes .. downlaod 1.1.3
maf2003
Sep 24, 2007
26
NO! Do not upgrade to 1.1.3. if you then your going to be stuck with a $400 paper weight for a while. yeah i was reading it. im waiting for a jailbreak and unlock to come out for it and you should too.
