Help, how to back up contacts on a PC
Sep 1, 2007
Hi everyone... need some help. I have a PC without outlook. How do I backup my names and phone #'s... that is all I am really worried about, incase my iPhone crashes, or I lose it etc.
Thanks so much... couldnt find the answer through the search methods.
jlhollander
Aug 17, 2007
175
Chicago, IL
You can back everything up using windows address book. or you can buy a mac... I use windows address book for the time being, and while it is not the best of programs, it gets the job done.
Lon
Jun 5, 2010
2,946
132
Alaska
weibin.li said:
Now I found and recommend this third party software called "GodswMobile Contacts Transfer" for Windows Mobile phone to transfer contacts to your laptop computer.
GodswMobile Contacts Transfer is a simple program designed for mobile phone running Microsoft Windows Mobile 5.0 or 6.0/6.1/6.5.
It can transfer contacts from cellphone to pc;Transfer both sim card contacts and outlook contacts;Transfer contacts to any other windows mobile phone;Transfer contacts customizer photos and ringtones;Manager contacts on pc.
In a word, you can backup and manage mobile contacts easily on your pc with GodswMobile Contacts Transfer.
Key Features:
* Transfer both sim card contacts and mobile outlook contacts;
* Including an app for PC to view,add,delete,modify and print contacts;
* Restore contacts to any other windows mobile phones;
* Backup contacts as TXT file and CTS file;
* Backup contacts pictures and ringtones;
* Support unlimited contacts backup/restore;
* Support VGA and WVGA Screen (such as HTC Touch HD/2 and Diamond/2).
Snapshot:
http://www.godswmobi...-mobile-scr.jpg
http://www.godswmobi...bile-phone6.jpg
Read More: http://www.godswmobi...-phone.html#q21
Geez, and I thought it was a pretty simple question. What is with that?
Hare
Jul 27, 2010
This is a fast and easy way to backup your contacts:
http://itunes.apple.com/us/app/idrive-lite/id295113646?mt=8
