Help: How to set usage back to Zero?
afterall
Sep 16, 2007
I used reset button but thats only reset my call time, the lifetime of the iPhone still indicated, is there anyway i can reset everything to Zero?
rondz
Jul 13, 2007
180
Bay Area
I think the only way to set the "Usage" back to zero is by giving your iPhone a full charge.
forkee
Sep 6, 2007
348
resetting the lifetime calls made
if you want to reset the lifetime counter that shows how many minutes youve talked since youve activated it, you need to do a full restore from iTunes. at least thats what i found out when i had to do a restore.
mickey35
Sep 5, 2007
54
At last a string that might answer my query.
I would like at the end of each billing period to reset "current period call time" and still leave "lifetime call time" untouched.
If I "reset statistics" does that accomplish this?
iPhone G3
dturner
Dec 15, 2007
5,725
Louisville, Ky.
iPhone G3
Yes it does. It takes "current" and the data fields to zero. Lifetime is untouched.
