help, i have bought parrot car kit which plays mp3's but wont work with iPhone?
Dunale
Nov 22, 2007
i have the new iPhone and music on it, i have just bought the parrot mk6100 which will play mp3's but it doesn't work from the iPhone?
does anyone know why?
please help as the parrot ki was very expensive and now seems useless!
jjvaldez
Jul 3, 2007
2,615
34
Salinas, Ca
call the company and ask if it is compatible with the iPhone.... that i all that i can think of.. it also helps to do this when buying an expensive device..
Dunale
Nov 22, 2007
i was advised that it would work.
the unit plays mp3's so that could be the prob.
even when i convert my iTunes music to mp3 it still doesn't pick it up? very odd
jjvaldez
Jul 3, 2007
2,615
34
Salinas, Ca
yes that is weird... do you have another mp3 player that you can use to test this device?
Dunale
Nov 22, 2007
unfortunately know, but the guy who installed it said it worked fine on his fone, a nokia something or other. so i know it works
its gotta be to do with the way the iPhone or i products store the music
cant be mp3 must be a derivative thereof
Dec 6, 2007
It wont but i know what will......
There is a simple reason it wont work and that is the iPhone cannot stream music via Bluetooth.
The kit will work as a bluetooth handsfree kit but not to stream music. There is only one product i know that can do that and that is on the link below.
http://www.connectmycar.com/node/2159
Dunale
Nov 22, 2007
yeah, im a bit more clued up on it now
the iPhone don't stream a2dp because basically Apple are sh#ts!
there is a dongle that will fit the ipod port at the bottom of the fone from 8bananas that will stream a2dp on the iPhone. its from america and costs $75.
http://www.8bananas.com/products/srs-200bd.html
can i also recommend for the fone
the invisible shield full body cover
http://www.shieldzone.com/item_description/APLiPhone.html?gclid=CP_h_-6wlJACFQ5OQgodxg4aAA
its extremely fiddly on the corners etc but hell its money well spent!
