*** Help...I'm Stuck...What do I do? ***
JailBreak
Nov 7, 2008
:mad:
I have a 16Gb iPhone 3G and jailbreaked it with QuickPwn a month ago (v2.1). Today, it rebooted and I'm stuck at a Steve Jobs graphic (see below):
What do I do? When I connect it to my Windows PC, iTunes says it needs to restore and when I click restore, iTunes says:
Do I go ahead and click the "Restore and Update" button? Will I have to re-jailbreak?
Thanks in advance!
xcissexc
Aug 9, 2007
501
yes hit restore and update. you will have to rejailbreak
JailBreak
Nov 7, 2008
Thanks. I'm doing that now.
So, what happened? What causes this? Is there something I need to do (or not do) to avoid this next time?
xcissexc
Aug 9, 2007
501
probably an app that you recently installed caused this crash
jsntrenkler
Sep 22, 2008
942
Tucson Arizona
проверять is what appears when you ask Google Translate to directly translate the word check into russian. Doing some search's on the web it seems that nPEBEД is the same thing. However I could be totally wrong.
unnecessary
Jul 20, 2008
149
You're right -=D
xcissexc
Aug 9, 2007
501
wait....so what does it say?
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
I read somewhere that it's a play on words (in Russian). It's "hello" with a spelling mistake to make it say "perved"...as in you've perverted Steve's device.
