Help! Installer not working anymore!
MileHiPhone
Sep 28, 2007
77
I hope someone can help me. For some reason Installer will no longer update or install programs. The status bar will go through the downloading process, but then midway through the installing or updating process it simply exits installer and the program is not updated or installed. It will uninstall programs. I am running 1.1.2.
Any ideas? What will I do with my days if I can no longer anxiously check Installer for new apps?
Thanks for any help.
p.s. I did search and saw that others have had problems that are at least similar if not the same. The only advice was to restore -- I am hoping for some other pearl of wisdom if there are any. I have four pages of apps and all sorts of customizing and would rather not redo that. In fact, if that is my only option I'll stick to putting new apps on with IBrickr I guess. Thanks.
themanofthedark
Jan 5, 2008
2,674
26
Boston
Thanks.
Too. Many. Apps.
Rather, too many big apps.
Uninstall unneeded crap from your springboard.
Things you never use. Then reboot, and try updating or installing new things.
What the hell are you doing with four pages of apps? Is that with skip last row? Or no?
Dec 10, 2007
710
blacked out
mhm.. Darkside, I suspect that it's either his connection or the installer server. The phone has plenty of ram/rom to rock tons of crap. Unless he's having slow load times for any given app, I'm gonna say it's a network issue.
themanofthedark
Jan 5, 2008
2,674
26
Boston
But the op says he downloads fine its the installing part that screws him.
Sometimes 1.1.2 does that, I don't know why, really.. When I was on 1.1.1, I had like 59 springboard icons.. And I think that was the glass cieling. I think the springboard just can't display a certain number of icons
But maybe I'm wrong.
Happens.
Dec 10, 2007
710
blacked out
that makes sense, Dark. I think you're right. Once it's d/l'd the phone makes the install and cleans up the files. MileHi, you might want to try reducing a few of the apps you don't frequent as a test.
MileHiPhone
Sep 28, 2007
77
hmmmm. Interesting. Thank you both foe the input. I have tried both on edge and wifi. Is there a way to increase the room allowed for apps and stuff? I only have approximately 246 mgbs or so of non-music/video stuff. I don't really have a bunch of stuff I don't use. One page of games, one page of original stuff, then useful things like camera pro, books, HP calc, finder, squid, sketches, etc.
Thanks.
patrickj
Sep 2, 2007
6,221
445
Austin, Tx
ipadinsight.com
You said you have Finder on there - so to check the theory on app being there, but Springboard not displaying it, you can go look to see if the app made it to the /Applications directory ...
Dec 10, 2007
710
blacked out
Thanks.
wow only 246 megs of free space? You're definitely taxing your phone. You might not have enough room to install anything.
themanofthedark
Jan 5, 2008
2,674
26
Boston
No no I think he means he has 'only' 246 mb of apps and stuff on it.
waning that the cieling might be on 250mb or 52 icons (for 1.1.2)
Ladies and gentlemen, may I present to you, yet another eager awaitor of the iPhone SDK..
[applause]
Oh by the way in no way that was meant to be seen as a personal attack.
MileHiPhone
Sep 28, 2007
77
Too. Many. Apps.
Excellent diagnosis! You were right on. Fortunately, Boss Tool was available in the recent packages section of Installer and the description seemed like just what I needed -- moving apps to make more room! So I deleted some stuff until Installer would work again, then installed Boss Tool and moved my wallpaper, ringtones and apps. Now everything works again. Thanks for your help!
:laugh2:
