Help iPhone 0mb download 2mb upload
Dec 6, 2013
www.facebook.com
I'm pulling my hair out why does my download not even get 1mb when upload does says I have full signal bought a booster no avail grrr help please
Sent from my iPhone using
5,578
Reset your network settings on the phone and power cycle the router. Contact you ISP if other devices on your network are experiencing the same problem.
Ledsteplin
Oct 29, 2013
4,843
997
65
Florence, AL
I was getting readings like that in a room 30 feet from the room where my modem was located. Turned out to be metal in the signal path. A big 26 cu ft fridge. I pulled the fridge out about 3 ft, and the download went from .67 Mbps to 12 Mbps. Rebar in walls can disrupt wifi signal. @Europa's advice should work.
Sent using iCafe app
Dec 6, 2013
www.facebook.com
Thanks guys, I figured it out! Believe it or not we just had a baby recently and he has an AngelCare baby monitor that has a camera and various other features with a wireless monitor station in our room and this was using the same channel as my iPhone/pad too! Hence low download! Cheers for your input though its appreciated
