Help! iPhone 3GS unlock query
wozmcnoz
Jul 11, 2012
I have searched in a lot of places and cant find an answer. Any help would be much appreciated.
I have been given an iPhone 3gs and i am trying to unlock it. i understand that with this band width it is not possible even after a jailbreak.
So i have followed instructions to convert to 6.15.0 then downgrade to another band following the instructions from the following site: http://www.iPhonejailbreak.me/how-to-downgrade-iphone-3gs-baseband-5-16-02-5-16-05-5-15-04-or-5-14-02-to-5-13-04-for-unlocking/
When i get to stage 8 tinyumbrella will not allow me to exit recovery because it is greyed out. is there another way to bypass error 1015? I have tried using recboot, but this did not help.
Any ideas/instructions would be much appreciated either when to bypass 1015 or to unlock the phone for use on any network.
If i have missed any instructions, please let me know.
fury
Oct 23, 2007
2,274
236
35
Louisville, KY
Try closing iTunes before running TinyUmbrella or RecBoot to get around error 1015
Other than that, only thing I can think of is start over and try DFUing 4.1 again
What are the first 5 digits of the serial number? (seen on the SIM card tray)
You need to know that to be sure whether you can even use 6.15.00 baseband
wozmcnoz
Jul 11, 2012
Have tried with iTunes off... no luck. Tinyumbrella has all options greyed out. Recboot says failed to start because libusb0.dll was not found.
fury
Oct 23, 2007
2,274
236
35
Louisville, KY
You can find LibUSB here: http://sourceforge.net/projects/libusb-win32/files/
Just out of curiosity, is the phone stuck at the recovery mode screen (iTunes logo, USB cable), or is the screen completely off (i.e. still in DFU mode)?
Try rebooting it yourself, by holding the home and power button for about 5 seconds or until the screen shuts off, then press the power button for about a second
wozmcnoz
Jul 11, 2012
It is in recovery mode. I have downloaded the illusb file from, then placed it in the recboot folder as the readme file says, but it still comes up with the same error message.
Cheers for trying to help with this, much appreciated!
fury
Oct 23, 2007
2,274
236
35
Louisville, KY
LibUSB is pretty tricky. Sometimes it wants to run in the Windows system folder, and other times, it's content to load it from the folder you're running RecBoot in. What version of RecBoot do you have?
Also, what version of Windows are you on, and is it 32 or 64 bit? (You can tell by holding in the Windows key and pressing Pause/Break. Somewhere, it will say the version of Windows, and "64-bit Operating System" or "x64 edition" will appear)
wozmcnoz
Jul 11, 2012
Hey thanks for your help. I bit the bullet and took it to someone to sort out for me... Was getting a bit out of my depth!
Cheers anyway!
fury
Oct 23, 2007
2,274
236
35
Louisville, KY
I'm happy to help, or at least try
Did they say what was wrong with it, or what they did to fix it? Might be handy to know for future reference in case I run into this kind of thing again
