iPhone 6 Help! iPhone 6 black screen dropped
JWA
Apr 8, 2016
Hi there, dropped my iPhone 6 and now is completely dead. Black screen, no sound, no vibration. It is currently on charge and u have tried holding the power button and home button to reset but no luck :( I have rung my phone using my gf phone and it doesn't go straight to answer machine - it rings but my phone just stays black, no sound or vibration. Any help please??
iPutz
Nov 20, 2012
964
183
43
73
US Midwest
Sounds like you may need to make a trip to the nearest Apple Store. Did you get AppleCare+ when you bought the phone? If so it is still under warranty. Good luck. Let us know the outcome.
JWA
Apr 8, 2016
no I haven't got applecare+ or any insurance . But it is 11 months old so technically just under warranty? The screen doesn't appear to be smashed
Does iTunes recognize it? Try restoring it on your computer. If that doesn't work and there are no visible signs of damage, Apple will likely replace/repair it for free. It could be a loose connection. Make an appointment at an Apple Store.
