Help: iPhone Contacts Missing
adriancwm
Dec 1, 2011
Singapore, Singapore
Hi all
Need help. My previous phone was a iPhone 4. After I sold my iPhone 4, I added a new hard-disk to my pc. The old hard disk is still inside, although the capacity is almost full.
Here's the problem. I recently bought a new iPhone 4S. Now I want to SYNC the old contacts (stored on my old hard-disk) to my new iPhone 4s. How do I do that?
Summary: now I've got a new iPhone 4S and a new hard-disk inside my PC. How do I look for my old contacts (in the same PC, but another hard-disk) and sync it to my new phone?
Is this really a complicated issue?
Please HELP...
Lon
Jun 5, 2010
2,946
132
Alaska
What Address Book program are you using on your new HD? And on your old one.
rambo47
Apr 4, 2010
528
79
Northern NJ
You *should* be able to tell your contacts app on the new hard drive to import contacts. When you do this you will have to navigate to wherever they are stored on the old disk (connected) and select that location.
adriancwm
Dec 1, 2011
Thank you Sir. But I'm NOT tech savvy, and so I don't know how to do all those things you've said.
Lon
Jun 5, 2010
2,946
132
Alaska
Or if running Outlook, export contacts from old drive as pst file and import into Outlook on new drive and sync iPhone with Outlook through iTunes.
Lon
Jun 5, 2010
2,946
132
Alaska
Or once you get your contacts onto your new HD download the iCloud Control Panel and sync PC contacts to iCloud, then sync from iCloud to your iPhone.
sera
Dec 23, 2011
32
Australia
I updated my iPhone 4 and somehow my contacts book has gone missing and I cant find it in either iTunes or my iPhone.
Is there any way of getting it back?
iP5
Sep 7, 2010
2,964
136
Toronto
Try a spotlight search from left most screen, for "contacts"
Sent from my mobilephone using Tapatalk
sera
Dec 23, 2011
32
Australia
Thanks for the reply :)
I did try that but nothing loaded.
Ive been told its not possible to delete your contact book from your iPhone yet mine is definatly gone.
iP5
Sep 7, 2010
2,964
136
Toronto
Wait for some of the more technical iPhone people to chine in but I'm think restore add new should reinstall the base apps for you. Just copy your personal data off the unit.
Bennyboy
Jul 21, 2010
14,017
1,731
PA
Do a hard reset. hold the home button and sleep button at the same time, don't let go till after the phone turns off and Apple logo appears and disappears again. Wait few seconds and turn your phone back on.
Jmbaker429
Jun 28, 2010
994
144
35
Don't know if
You have tried this already but when you update to ios 5 it moves contacts into a folder. I thought the same thing, that it was gone. Have you looked everywhere. If all else fails make sure your phone has been synced and restore and set up as new. If that doesn't fix it then you'll have to make a appointment at the genius bar with Apple. Hopefully this helps
sera
Dec 23, 2011
32
Australia
Hey everyone thanks so much for the responses :)
I did manage to get my contacts app back thanks to all your help, but now it is empty!
I do remember when I was doing the update, iTunes asked me if I wanted to back up everything from my phone and I chose to do so.
Would my list of contacts be in there somewhere?
Bennyboy
Jul 21, 2010
14,017
1,731
PA
Check your phone app and see if they are there, if they are just click on any of them and they should appear on your contact app list.
sera
Dec 23, 2011
32
Australia
No, nothing, Ive had to re-add the numbers that I know, but have lost all numbers I don't know off by heart
