Help - iPhone Crashing at least once daily
EverythingApple
Jul 28, 2010
3,862
225
North Jersey
I'm on iOS 7.0.4. But, lately, my phone has been crashing a lot. And, apps have been crashing too. I haven't added any new tweaks, just updated installed ones.
If I do a hard reset, it helps with the apps crashing until the next time.
Any ideas? Any culprits? Thanks!
Jun 19, 2007
33,478
4,542
Upper Marlboro, MD
Update to 7.1, maybe, unless you're jailbroken?
Interestingly enough, I had my first Safari crash in over a week replying to this post. I'm on 7.0.6.
28,365
5,506
What types of crashes are you having? Resprings, Sade Mode, app crashes to the home screen? Which apps? Do you have a 5s?
Install Crash Reporter in Cydia. It can help you find Cydia culprits. Also, check your Apple diagnostics report/crash logs. This can even be done on a stock phone. Sometimes the crashes are a result of 64-bit. It will tell you if the crashes are a result of low memory, which is common on the 5s.
Settings > About > Diagnostics and Usage > Diagnostics and Usage Data.
28,365
5,506
Look for these (lowmemory) immediately after your crash. It's the stock Crash Reporter and it's often more useful that the one in Cydia because it tells you why it happened if the problem is on Apple's end rather than a Cydia app.
EverythingApple
Jul 28, 2010
3,862
225
North Jersey
I guess you can't read my signature on the mobile site. I'm jailbroken on 7.0.4 on an iPhone 5.
The Cydia crash reporter doesn't show anything any culprits.
Re springs, sometimes to safe mode, apps crash to home screen. No specific apps.
EverythingApple
Jul 28, 2010
3,862
225
North Jersey
Which one?
iSyslog - System Monitoring, Analysis & Reporting by Karoly Nyisztor
https://itunes.apple.com/us/app/isyslog-system-monitoring/id468155763?mt=8
CrashReader by Meatfreezer LLC
https://itunes.apple.com/us/app/crashreader/id446584362?mt=8
Or, is it another one?
28,365
5,506
EverythingApple
Jul 28, 2010
3,862
225
North Jersey
Most recent crash was a LowMemory one. How do I clear memory? Is BatterySaver a good app to do it to reallocate the memory. I have it and just ran it.
28,365
5,506
Reboot once or twice a day and see if that helps.
28,365
5,506
So mobile safari just crashed to home screen. I checked out stock crash report. Anything I should be looking for? There's a lot if info there. Thanks!
They have the times listed. Check for any that say lowmemory.
EverythingApple
Jul 28, 2010
3,862
225
North Jersey
It crashed again. Nothing on low memory. This was in the MobileSafari crash report:
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Subtype: KERN_INVALID_ADDRESS at 0xa1568667
Triggered by Thread: 7
Does this mean anything or help?
28,365
5,506
I'm not sure what you can do other than restoring to 7.1, unfortunately.
EverythingApple
Jul 28, 2010
3,862
225
North Jersey
I'm holding out for a little while. I love jellylock7 and getting used to my themed icons.
If I do restore, I should do it through iTunes correct? Any recommendations how to do it so it does fail?
28,365
5,506
Update or restore in iTunes. Don't do it unless your 100% sure it's worth losing the jailbreak. There's no going back.
EverythingApple
Jul 28, 2010
3,862
225
North Jersey
Thanks! I'm going to keep the jailbreak for now. It rebooted again, but not to safe mode. The reason was LowMemory. Why do I keep getting these low memory crashes?
Pirkez89
Apr 5, 2014
9
i have The same problem! Look The video
EverythingApple
Jul 28, 2010
3,862
225
North Jersey
I happened again 6 times in a row (total 7 today). It would go into safe mode than crash when I hit restart. I almost restored. But now it's okay. It usually only crashes to safe mode once or twice a day and not after one another.
The only new items I added yesterday were the NJJurors App Store app and Almpoum from Cydia. And I backed everything up to PkgBackup in anticipation of a possible restore before my 6 in a row, but that shouldn't have caused the crashes.
Any ideas/suggestions? Thanks!
