Help iPhone speakers?
Mar 2, 2007
Hey guys, I only have sound coming from my left buttom speaker when I use the ipod or play ringtones. Is my iPhone defective or what. Please help.
Left button speaker? huh?
Do you mean the left headphone?
Try resetting the connection. In other words, pull the connection loose, and put it back in, firmly. Make sure it goes in all the way. If the connection is loose, then that 2nd or 3rd ring on the headphone plug will not make contact, and it will go to "mono" or left-channel only.
