help jjvaldez please :(
jjvaldez
Jul 3, 2007
2,615
33
Salinas, Ca
ok this is the deal.. i have 2 issues.. on is that my phone will not connect to iTunes.. i have a jailbroken 1 1 3 iPhone and 7.6.2 iTunes..
another thing is that i have lost all sound on my iPhone and the videos wont play.. this happened after i installed band from moo... any suggestions please ... i cant even talk on my phone or hear my voice mails..
thanks
24trepid
Jan 13, 2008
502
Sounds like you may have to do a restore.
Sorry, but it happens......:(
Bone
Feb 11, 2008
1,214
So the phone is on and functioning it just won't produce any sound? Have u tried reseting general settings yet?
patrickj
Sep 2, 2007
6,221
445
Austin, Tx
ipadinsight.com
You've probably already tried this, but I've lost all sound a couple times and got it back right away by just doing a reset of all settings. It means you have to do things like re-enter your home WiFi password and some other prefs, but may be a real quick fix for sound ...
psylichon
Oct 31, 2007
16,591
751
41
Philly
ditto the above. That should be all you need to do.
Yep, that should solve the sound issue. As for the iPhone not connecting to iTunes, have you tried using a different USB port? Changing ports often fixes the issue.
- John
jjvaldez
Jul 3, 2007
2,615
33
Salinas, Ca
hahahahaha yes! EIC and all its members FTW!
thanks all
.. now for getting it to read this ... anyone tried band? i uninstalled it . should i try it again?
jjvaldez
Jul 3, 2007
2,615
33
Salinas, Ca
tried the different port thing... not working either...
patrickj
Sep 2, 2007
6,221
445
Austin, Tx
ipadinsight.com
thanks all
Cool - glad you got sorted out quick. I'm using Band since last night without any probs so far. I'm just a bit worried that if it has any sort of 'You are tone deaf and should not be allowed near instuments, ever' detection system, it may find me out soon :)
connie
Jul 11, 2007
2,839
104
So Cal
I have had this problem when I install new stuff off of installer sometimes. I actually had this problem every time I installed one of the Customize versions. I have been kind of nervous to install new stuff because of it. It freaks me out when I suddenly have no sound and can't use the phone.:eek:
H
Hayesimus
Guest
any time I've ever had an issue with iTunes recognizing the iPhone, I restate both the iPhone ad the computer and it has solved the problem.
