Help me (or i have to restore)
Techno_man
Oct 27, 2007
56
hello ppl i need some help this is strange when i install some widgets to my iPhone it said "you cannot make phone call" ! now why is that ! it's so annoying ! anything to fix this i don't want to restore please help asap
KNK
Jul 22, 2007
2,391
Stevenson Ranch
What is the status of your phone?
Techno_man
Oct 27, 2007
56
the phone is running ! but i cannot tap any number or call any contact ok here's the message i get : Repair needed iPhone cannot make or receive call got to www.iPhone.com/support but my iPhone is jailbreaked its not legal so help ! :(
termleech
Sep 7, 2007
1,154
McPherson, KS
Sounds like you don't have any choice but to restore the phone and re-jailbreak it. Sorry man.
connie
Jul 11, 2007
2,839
105
So Cal
Even if you needed Apple's help to fix the problem you would still have to restore anyways. Maybe if you restore it will fix the problem without having to go through Apple support. It will be a pain in the butt to do the jailbreak all over again but at least your phone will work.
Techno_man
Oct 27, 2007
56
i had to restore but yet it didn't worked so i restored to an updated version i was using 1.1.1 but when i restored to this version it didn't worked i had to restore to 1.1.2 then restore back to 1.1.1 (activate jailbreak unlock) but the unlock didn't worked so i had to downgrade my baseband and then restore to 1.1.1 but the problem now is when i go to www.jailbreakme.com and do the procedure when it finish and boot the booting takes forever with no response! if anyone can help please assist me, i will try my best to make it work :(
termleech
Sep 7, 2007
1,154
McPherson, KS
How long is forever? I know when my brother did his jailbreak on 1.1.1 it took like 15 minutes for the reboot. I know that's not normal, but I have seen it happen before.
Techno_man
Oct 27, 2007
56
15 mins! no i didn't waited that much only like 5 mins but it should work within 5 mins
KNK
Jul 22, 2007
2,391
Stevenson Ranch
The reason it takes so long is it is downloading something and it takes time. Also had to do it a couple of times in a row for it to work.
Techno_man
Oct 27, 2007
56
Hey Buddy! guess what i restored to 1.1.1(also tried 1.1.2 then 1.1.1 couldn't go back to 1.0.2) and none is working! after the jailbreak on 1.1.1 the iPhone go into an endless boot! :( how can i restore to 1.1.1 with another way or 1.1.2 (but i done nothing so i guess the iPhone is not prepared also the jailbreakme site isn't working on this firmware)..
KNK
Jul 22, 2007
2,391
Stevenson Ranch
Ask the Tinman or MacManPro for help, they arte the Genius men who can help you.
connie
Jul 11, 2007
2,839
105
So Cal
Try to connect to iTunes. When mine got stuck rebooting thats what made the phone finally wake up and go to the homepage so I could turn on wifi to continue. There are so many steps that if you miss just one thing it won't work. I had to do it several times and the connecting the phone to computer and opening iTunes was what finally made it work for some reason.
Techno_man
Oct 27, 2007
56
first i want to say big thanks for all the support i appreciate that.
Some how i tried to restore to 1.0.2 and now i am trying to jailbreak via apptapp software it will take about 2 hours let's see if this works, i really don't care which version i use in the meantime i just want my iPhone alive again to use my phone
meiphones_brill
Nov 16, 2007
797
I'd suggest picking a guide - checking with people here that you have the right guide - and then follow it to the letter.
It does sound as if you're trying things at random 'just to see if it works' and this isn't very scientific, and rarely successful. You need to know what state your phone is in - know what needs to be done to it - and do EXACTLY the right things to it to make it work.
I understand how frustrating it is when nothing seems to work, but It's just as painful to see someone struggle for hours when it's actually 20 minutes work at most.
Techno_man
Oct 27, 2007
56
The restore done but i cannot unlock my sim card with anysim actually it says successfuly unlocked but my sim card has no signal (this also happened with me on 1.1.1 when it worked!) :(
When i connect to iTunes it says that there is no sim card power off and put sim but there is a sim card ! why is that happening and how i can fix it i just want the phone back to normal!
Feb 5, 2008
11
After having other problems and trying to go back from 1.1.3 with a supposedly 3.9 bootloader I am not in this situation with the sim card error and also the Repair Needed error.
Anyone able to help at all?
