Help! my 8GB turned into 300MB!
Techno_man
Oct 27, 2007
56
Yesterday i updated my iPhone to 1.1.2 then i had some problems i downgraded to 1.1.1 and after jailbreaking today i noticed that the 8Gb storage is lost and i only have 300MB! (this is showing on the iPhone and iTunes :( )
i found a 300MB fix file on the forum but it's for mac! i need a windows working one
please help :mad:
Techno_man
Oct 27, 2007
56
Nevermind i fixed it :D
here's the solution if anyone have this prob
This is how to fix your iPhone after jailbreaking or unlocking, then connecting to iTunes it says it only has 300MB.
Step 1. Get Installer.app on your iPhone, if your firmware is 1.0.2 or older (Settings>General>About) use Apptapp from: http://iPhone.nullriver.com/beta/ If your firmware is 1.1.1 go to jailbreakme.com from your Safari browser.
Step 2. Install BSD Subsystem on your iPhone Install vt100 terminal on your iPhone. Type in:
cd /private/var/root Then: mv Media Media_sym Then: mv Mediaold Media Then Reboot the phone, this should fix it.
