Help please, maps won't find directions unless Locations services is on
kimo
Aug 7, 2007
169
You will have to turn on locations services in order to get directions. It would be same for any app which provides directions from point a to point b.
Jerome G
Jul 12, 2010
245
I did not have to on this on my iPhone 4, running iOS prior to 5.
I only had to do it when getting directions from my current location, but not if I am just picking 2 locations.
Bennyboy
Jul 21, 2010
14,017
1,731
PA
If location service is off on maps there's no way it could find your location.
Lon
Jun 5, 2010
2,946
132
Alaska
I just turned off location services on my iP4S and got directions to and from 2 of my contact's addresses.
Bennyboy
Jul 21, 2010
14,017
1,731
PA
Yeah, I see that now, you have to enter your location manually thou, that's about it.
kimo
Aug 7, 2007
169
If you want to get directions from location to another (not necessarily current location) then go into directions and manually enter both. This can be done if location services is turned on.
Lon
Jun 5, 2010
2,946
132
Alaska
If you want it do automatically and easier then turn on location services. If you want to do it harder then you would need to type in manually for both address (or use a drop pin for the end). Your choice.
If you are not using your current location, then it is not faster one way or another. Either get addresses from contacts or manually enter (or drop pin, as you said).
Jerome G
Jul 12, 2010
245
I must be doing something wrong then, this does not work for me with location services off.
I usually look up a location that I want to go to, then enter my home from "contacts", but the phone gets stuck on "loading" directions.
