HELP PLEASE weather & stock arn't working
Nov 24, 2007
319
HI, i i'm jailbroken & on 1.1.3.. i installed "weather icon fix" works on 1.1.3 too... from the "tweaks" in installer.. my weather stopped working... wouldn't stop refreshing.. so i uninstalled "weather icon fix" hoping that would fix the problem... still samething... but then i got thinking retardedly...i backed up all my applications 2 days ago on my laptop... so instead on just renaming .app folder i deleted it and copyed over the backup from 2 days ago... now i get nothing at all it opens then crashs after 10 secs.. i don't see the little "i" anymore ether... my stocks won't work ether.. same problem, won't stop refreshing... any ideas on how to fix the weather? you guys have any problems or is it just me?
partizan
Feb 25, 2008
302
Milton, Ontario
Same Problem on 1.1.4
I'm having the same issue with weather and stocks this morning. I'm on 1.1.4. Last night they both worked fine.
Nov 24, 2007
319
THANK YOU... i got it working to were it wouldn't stop refreshing again.. whats the odds on that, it doesn't work when i go to install a fix..
Hondamaker
May 14, 2007
9,946
671
56
Fairborn, Ohio
usually it's a yahoo thing, since they are connected to yahoo. I have the same problem every so often, it's always both weather and stocks, nothing else. Server issues or something like that.
I was having the same problem Friday morning. They both work now.
- John
