help problem while upgrading to 1.1.4
sulysoul71
Dec 11, 2007
Hi everybody. I got this problem which i searched for answers through many forums, but i couldn't find an answer for it. I have an iPhone with firmware 1.1.1 which is working flawlessly, so when i read that upadating firmware to 1.1.4 was so easy using ziPhone i couldn't hold myself from trying. So downloaded the 1.1.4 firmware and rebooted my iPhone in recovery mode, then using iTunes 7.6.1 i pressed the restore button while pressing on the shift key to search for the 1.1.4 file stored on laptop. After choosing the right firmware it started restoring suddenly this message comes up " the iPhone could not be restored. An unknown error occurred (5)". I do the same steps to return to firmware 1.1.1 and then using ziPhone 2.5 without any problems. So guys what should i do, its really pissing me off. Should i download the firmware 1.1.4 again or am i doing something wrong here. Really confused guys. Appreciate all the help i can get.
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
You don't seem to be getting any replies here. I would check the iPHone Modifications or the iPHone Software forums to see if you can find your answers there. This forum is for more general iPhone discussion.
sulysoul71
Dec 11, 2007
Thanks a lot i will check them out.
