help problems with installer
wbrod
Oct 25, 2007
25
my installer is crashing, after it download an application trying to install it but it crashed me back to the spring board. Any suggestion?
thanks in advance
Griffinaz
Oct 5, 2007
1,046
Phoenix, Arizona
thanks in advance
At what point does it crash, right as it finishes installing, during the actual installation or afterward when you exit the installer software itself? If it is crashing during the actual installation process then you may have a problem with your phone not being correctly jailbroken and it is trying to install to a directory that it does not have permission to write to. In that case you would probably need to restore and re-jailbreak it. If it crashes afterward when your exiting the installer application itself then it might not actually be crashing. When you install software (most) and exit the installer it will automatically reboot your phone so the new program is visible.
wbrod
Oct 25, 2007
25
ok, iam going to restore, but my iPhone is activated with att and original version 1.1.1 should i just restore and jailbreak and stay at 1.1.1 or if it safe to upgrade to 1.1.2 already. Any different between 1.1.1 and 1.1.2? I always thouhgt that it was safer to stay at 1.1.1 but i don't know. Any suggestions?
thanks un advance...
KNK
Jul 22, 2007
2,391
Stevenson Ranch
Usually everyone is going from 1.1.2 downgrading to 1.1.1, so you should stay there.
wbrod
Oct 25, 2007
25
Ok thanks. Since i am with att, whar is the best to restore to stay in 1.1.1 and jailbreak?
