Help the iPhone virgin
cascrapsky
Nov 6, 2007
Please help me with these questions, as much as you can answer. Thanks.
1) I'm thinking of buying a software unlocked iPhone with version 1.1.1 i heard if Apple updates the firmware (?) that it will brick it, or it will disable some applications? Is that true?
2) What are the downsides to unlocked iPhones?
3) I'll be using it with T-Mobile, anything i should know? Does it work with t-zones?
4) Will i be able to be notified when i receive an email?
5) Will the Wifi be 100% usable with any (unsecured or known password) hotspot?
6) Would it be cheaper to buy it and unlock it myself or buy it already unlocked? And where do you get locked ones (without a contract)?
Any future risks or anything else i should know before i spend $500?
Thanks a lot in advance :laugh2:
akilgore23
Oct 24, 2007
51
Albuquerque NM
If you don't mind me asking how much would you be paying for the unlocked iPhone?
And for tthe questions
1 yes
2 the things ive heard is no visual voicemail and maybe some small stuff like red voicemail indacator stays on and maybe no youtube. But im sure someone else can answer that one better
3 & 4 not too sure about
5 Yes
6 you can always just get the iPhone from an Apple store and not activate it
on and sorry if this doesn't help
I'm sure others will answer more in detail
cascrapsky
Nov 6, 2007
$480 to 520.(ebay)
So will i get stuck with this firmware for ever?
and will text messages and multi media messages work?
And if i get it from an Apple store does it have to be a sertain,older firmware (unlockable)
thanks for the answers.
