Help! Unjailbreaking iPhone 5s, iTunes error 9006 when updating software!
ggordon4
May 25, 2015
I have an iPhone 5s with the Pangu jailbreak for iOS 7.1. I'm attempting to restore the phone and update to the latest software, 8.3, in order to remove the jailbreak. Whenever I try to, iTunes gives me error code 9006 when trying to download the software. I've tried restarting my PC, disabling security programs, and even downloading the iOS file and attempting to manually restore it from the file (using shift+left click on restore) When I do that, it says the file is not compatible, even though I'm sure it's the right one.
The jailbreak is causing a lot of problems on my phone and I would really, really like to get rid of it. Any suggestions would be immensely appreciated!!
Kadelic
Jan 4, 2010
4,938
1,645
Dallas, TX
Make sure you have the latest version of iTunes. Then reboot the PC again for good measure.
Dec 15, 2008
5,386
340
27
Pensacola, FL
28,365
5,506
Dec 15, 2008
5,386
340
27
Pensacola, FL
The OP said, "I've tried disabling security programs."
I know. I read it in its entirety after. But it also says to check USB connections. I just took the error code suggestions from Apple.
Dogs can't read. :p
28,365
5,506
Dogs can't read.
Please start reading threads more carefully before you reply. It doesn't help people when you tell them to take steps they have already taken.
