Help urgent- After installing iblacklist iPhone is not showing icons and restarting
amitjak
Aug 29, 2009
Today i insalled ifile and iblacklist through cydia, when it asked for reboot i did. After rebooting its fuctioning i mean i can SSH it and its showing in my computer as a camera but there is not display on the screen, no icons are showing. And after some time like 10 min its automatically restarting as well So is there any way i can uninstall those programmes and resolve this problem using SSH.
Thanks in advance
iphonewarrior
13,847
701
Have you tried a Hard Reset?
It sounds like you need to do either a restore or get those packages off, which can be done via SSH.
amitjak
Aug 29, 2009
Thanks for reply iPhonewarrior.
Hard reset means-Holding Power button and home button for some time so that it turned off and start again, right i did it but no use it stuck on the same place.
I can restore but i want to try SSH, if you know how to remove those files, i mean where they are located, please tell me so i will not loose many software which i installed and did not make any backup for them.
