Help with camera
Sinphil
Jan 7, 2012
11
Hi all. I was wondering is there a way I can take a picture just touching the screen not just the little camera button at the bottom of the screen? Thanks in advance.
Phil
Rugaby
Feb 18, 2011
7,122
1,172
Washington state
No. Not without jail breaking.
Here is a hint that might help you.
If you hold down the little camera button and then get the shot ready you can release your finger and the shot will get taken. I use this a lot with the my 3gs because it inly has the rear camera and works great with the extended arm pictures. Also with ios5 you can use the volume button.
Sinphil
Jan 7, 2012
11
Ah ok. Don't fancy jail breaking it. Thanks for your help. Much appreciated.
Phil :)
Happy iPhone 4 owner
iBoss
Oct 15, 2011
250
53
Also try using the Volume "UP" button on the side to capture a pic.
Sent from my iPhone4(S) iCafe
Bennyboy
Jul 21, 2010
14,017
1,731
PA
If you are looking for an app camera genius does it.
ps: big camera button is free, it's made by the people of camera genius, if you're just looking for the big button feature.
bams50
Nov 23, 2007
277
33
I use CP Pro camera app. Has that feature as well as a bunch more. Well worth the buck.
