Help with check & uncheck music
Lazarus
Jun 6, 2007
380
Miami
ok I sync my iPhone only the checked items right. So I accidentally unchecked everything at once. Please tell me there is a way to get it back to the way I had all 3,000 songs checked? I'll do a system restore if it will get it back to the way I had it. HELP!
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
There is a really easy way to fix this. Select all of the songs by either hitting Command or Control "A" and then right click. You should see the option to Check all selections. Then you're set.
Lazarus
Jun 6, 2007
380
Miami
no I want to get it back to the way I had them before. I had some checked & some not checked. Does iTunes not remember this?
