Help with custom iPCc file
Woody1776
Feb 26, 2008
115
DFW
hello all,
I've tried to search for a solution without any luck. Here's the rundown:
I have 3.0 gm installed
I have the iTunes beta 4 installed V. 8.2b7
I have the custom .ipcc file downloaded
I'm on a MBP 10.5.7
When I shift click to upgrade it won't let me select the .ipcc file.
When I downloaded it it was called ATT_US.bundle
I tried it and it didn't work
I changed it to this ATT_US.ipcc - it didn't work
I tried ATT_US.bundle.ipcc - it didn't work.
Please help! I feel dumb.
Chris Hyde
Oct 27, 2007
97
In order to use the IPCC that allows MMS and tethering, you need the first release of iTunes 8.2. The updated 8.2 doesn't give you the option to install new IPCC files. :)
Woody1776
Feb 26, 2008
115
DFW
iTunes 8.2b7 is supposed to be one of the last releases that allows you to load .ipcc files. Please let me know if I'm wrong and need another version of iTunes
shutter13
Jan 8, 2009
2,201
144
Did you download the ipcc file with safari? If so it probably unpacked it, download with a different browser.
iphun
Mar 16, 2009
1,967
PA
Yeah b7 was the first 8.2 and it allowed the loading of ipcc files.
Woody1776
Feb 26, 2008
115
DFW
Shutter - you are badass. I used Firefox instead of Safari. It worked the first time.
iphun
Mar 16, 2009
1,967
PA
I have 8.2.1.6 is this too late?
iTunes 8.2 is the one where they blocked it but that doesn't mean you can't find another way around that. The only 8.2 that allowed it was the first pre-release which you don't have.
Do this to Enable IPCC Updates for iTunes 8.2:
iTunes 8.2 will not allow you to apply the IPCC updates so you need to follow these steps:
MAC OS X:
1. Close iTunes.
2. Open Terminal (Applications > Utilities > Terminal).
3. Run the command: defaults write com.apple.iTunes carrier-testing -bool TRUE.
Windows 32 Bit:
1. Close iTunes.
2. Go to Start then Run and type CMD.
3. Run this command(If you right-click on the cmd window you can paste): “C:\Program Files\iTunes\iTunes.exe” /setPrefInt carrier-testing 1.
Windows 64 Bit:
1. Close iTunes.
3. Run this command(If you right-click on the cmd window you can paste): “C:\Program Files (x86)\iTunes\iTunes.exe” /setPrefInt carrier-testing 1.
http://www.iphonehacks.com/2009/06/hack-to-enable-mms-on-iphone-os-30.html
crupp
Sep 27, 2007
152
Atlanta
Thanks iphun. I have done the cmd so iTunes will look for the ipcc but iTunes does not see any ipcc in the ATT_US file
iphun
Mar 16, 2009
1,967
PA
No problem :eek:k:eek:k Is the file named ATT_US.ipcc exactly? iTunes will only see it if it ends in .ipcc. Also put the .ipcc on your desktop so you know where to look for it when you shift/option + check for updates. And you want the entire ipcc to be loaded on to the phone.
shutter13
Jan 8, 2009
2,201
144
Also make sure you change the file type from ipsw (what iTunes will look for by default) to .ipcc.
crupp
Sep 27, 2007
152
Atlanta
yup. No luck. Very weird. I have the file re-named to ATT_US.ipcc and iTunes will still not recognize it. I downloaded the zip with IE7, unzipped, re-named and nothing.
crupp
Sep 27, 2007
152
Atlanta
Got it! Unzipping was the problem. Working great so far.
Jul 15, 2007
27
Anyone had trouble with the cmd line working in xp or vista? I can't seem to get either to work.
iphun
Mar 16, 2009
1,967
PA
Are you sure all you are copying is:
Jul 15, 2007
27
i am using 64 bit and i am pasting C:\Program Files (x86)\iTunes\iTunes.exe” /setPrefInt carrier-testing 1
it says 'C:/Program' is not recognized as an internal or external command, operable program or batch file.
brn2prgrm
Aug 28, 2009
ok no matter what i try this command line mess doesn't work.
it just keeps giving an error saying: this system cannot find the path specified.
Whats with that?
rryyddeerr
Sep 8, 2009
hi, i was able to install the new ipcc, but now my phone says i am not subscribed to a data plan whenever i try to check my email or anything else. any ideas?
wd_stroke
Apr 12, 2008
114
You'll have to re-input your APN (Cellular and MMS) under Settings > General > Network > Cellular Data Network
