Help with ipsw problem
skydvn
Mar 24, 2008
I am trying to unlock my 2g 16gb iPhone with the tutorial on iClarified.com. Dowloaded all the files. Problem is that when I unzip the restore file it never makes an executable file. A box opens that says "The Path '1_3.0_7A341_Restore" does not exist or is not a directory".
What can I do to make the ispw file work?
I have the iTunes 9.0 is installed and I did a iTunes restore.
Thanks,
E.
5,578
It needs to be saved as a .ipsw file. Internet Explorer and Safari save it (incorrectly) as a .zip file.
Solution. Change the file extension or just delete it and download it with Mozilla Firefox. Firefox will save it with the proper file extension, .ipsw.
skydvn
Mar 24, 2008
All I did was add the ipsw extension at the end of the file when I downloaded. I am in the process of unlocking now. Will update later.....Thanks
