Help with Message tones
Rickster
Aug 28, 2011
20
Hi all,
Having downloaded a selection of messgae tones into I tunes, when I sync the tones go into the ringtones list on the phone.
How do I get them onto the message tones list so I can select them?
TIA
Rickster
bboy
Oct 13, 2010
there is currently no way to customize message tones on iphone-4. Try a new phone from a different manufacturer.
RoofMonkey
Jun 21, 2010
8,913
1,979
Maybe you can do the same thing for the problem you have with the home button.... Like you posted in another thread.
To the OP, you can change message tones but your device needs to be jailbroken first.
Sent from my iPhone
iphonewarrior
13,847
699
Hi all,
TIA
Rickster
There is no physical way to change the message tones on the iPhone other than selecting another stock tone. You must jailbreak your device and then you can replace the stock tones with custom ones you've either downloaded or created. It's fairly easy to do. :)
bboy
Oct 13, 2010
those wheels are already in motion my helpful friend.. and with no 'illegal' jailbreak 'solution' required.
Vcoronel127
Aug 30, 2011
119
Jailbreaking isn't illegal at all. The news states that upon purchasing your phone you can do anything you want to it because it's rightfully yours.
Breaking out of jail is though!lol
U.S Army
Sent from my iPhone 4
ed2438
Apr 9, 2010
365
24
El Paso, TX
If you have iOS5, you can change it without jailbreak. Might have to wait for that option if you don't want to jailbreak.
rambo47
Apr 4, 2010
528
79
Northern NJ
Geez, this blows! I have custom ringtones loaded on my 4s, they're in the proper format and length, and they play when I select them from the menu within Contacts. They get saved as the custom ringtone for each contact as well. But when the phone rings, the default phone ringtone is the one that plays.
rambo47
Apr 4, 2010
528
79
Northern NJ
Today the custom ringtone for one contact worked! Maybe they're all working now. Who knows? I didn't make any changes or even restart my iPhone.
rambo47
Apr 4, 2010
528
79
Northern NJ
As far as jailbreaking, there is a difference between carrier/manufacturer guidelines for use and the state/national laws. Jailbreaking is not illegal. Changing the IMEI of a phone may be.
