Help with modifying the Saurik Theme...
mflantin
Nov 29, 2007
100
Anyone out there familiar with HTML codes and played around with the Saurik Theme on Winterboard? The Saurik theme allows you to have a wallpaper that switches images every few seconds. I've figured out how to display the wallpapers I've chosen and have it switching every 8 seconds instead of 15, but for some reason, after all the wallpapers have cycled, it gets stuck cycling only two different wallpapers. Can anyone give me advice on how to change the HTML codes so that it cycles ALL of my wallpapers?
dsegel
Aug 13, 2008
Try posting the section you changed and we can see what you've done.
You may want to look into the iHour theme as it may be easier to modify to get what you're after.
mflantin
Nov 29, 2007
100
<script>
var images = ['Joker.png', 'Snowboard4.png', 'Boondock Saints.png', 'Blue Apple.png', 'Snowboard3.png', 'Bronze.png', 'Wallpaper.png', 'Widmer.png', 'Snowboard2.png'];
var index = 0;
var fade_in = one;
var fade_out = two;
fade_in.src = images[0];
fade_out.src = images[images.length - 1];
var fade = function () {
fade_in.src = images[index];
index = (index + 1) % images.length;
fade_in.className = 'fade-out';
fade_out.className = 'fade-in';
var fade_tmp = fade_in;
fade_in = fade_out;
fade_out = fade_tmp;
setTimeout(fade, 8000);
fade();
</script>
Does iHour allow the wallpaper to change every couple of seconds? I know it changes throughout the day, but I wasn't sure if you can set it to alternate every few seconds.
Jul 27, 2008
here you go. i editted it to do up to 9 pictures.
<?xml version="1.0" encoding="UTF-16"?>
<html><head>
<base href="Private/"/>
<!--meta name="viewport" content="width=320, minimum-scale=1.0, maximum-scale=1.0"/-->
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8"/>
<style>
body {
background-color: black;
margin: 0;
padding: 20px 0 0 0;
height: 442px;
width: 320px;
img {
-webkit-transition-property: opacity;
-webkit-transition-duration: 2s;
position: absolute;
width: 320px;
height: auto;
img.fade-out {
opacity: 0;
img.fade-in {
opacity: 1;
</style>
</head><body style="color: black">
<img id="one"/>
<img id="two"/>
<script>
var images = ['Plant.png', '1.png', '2.png', '3.png', '4.png', '5.png', '6.png', '7.png',
'8.png', '9.png'];
var index = 0;
var fade_in = one;
var fade_out = two;
fade_in = fade_out;
setTimeout(fade, 15000);
fade();
</script>
</body></html>
Make sure the pictures that u use are are "1.png" if not, change it to 1.png ,2.png , 3.png before you put the files into the device using Disk Aid or SSH
mflantin
Nov 29, 2007
100
<html><head>
<style>
body {
margin: 0;
height: 442px;
width: 320px;
img {
position: absolute;
width: 320px;
height: auto;
img.fade-out {
opacity: 0;
img.fade-in {
opacity: 1;
</style>
<img id="one"/>
<img id="two"/>
<script>
'8.png', '9.png'];
var index = 0;
var fade_in = one;
var fade_out = two;
fade_in = fade_out;
fade();
</script>
</body></html>
I've done this already and it does cycle all nine pictures, but for some reason after it comletely cycles all the pictures, it get stuck cycling only two of the pictures. I'm trying to figure out how to configure it so it always cycles all nine pictures instead of getting stuck with two.
Jul 27, 2008
I think you messed up something up in your saurik file because with that code it should keep on cycling the 9 cycles because that is telling what the theme should do.
cooljo555
May 11, 2008
THANKYOU very much for this, a have over 150 images now cycling and this was all i needed, the iHome theme doesn't cut it with picture for each preset time. Granted its not the wallpaper changing like rwallpaper does, but it just as good if not better because it actually changes with the time interval. If anyone figures out how to get rwallpaper on a jailbroke 2.2 it would be much appreciated.
Apr 21, 2009
I'm having some issues with this code. I added more pictures and added the correct filenames between the brackets in "var images = [...]"
The pictures do cycle, but during the transitions, there is a weird effect.
As the first picture fades out, the picture AFTER the NEXT (3rd) flashes for a brief second, before the 2nd picture fades in. It's like that for the whole sequence and looks horrible.
How can I fix this code so that the transitions are smooth from one picture to the next and have it cycle back to the first after the series is over? Thanks!
<html><head>
<!--meta name="viewport" content="width=320, minimum-sale=1.0, maximum-scale=1.0"/-->
<style>
body {
margin: 0;
height: 1024px;
width: 768px;
img {
-webkit-transition-duration: 1s;
position: absolute;
width: 768px;
height: auto;
img.fade-out {
opacity: 0;
img.fade-in {
opacity: 1;
</style>
<img id="one"/>
<img id="two"/>
<script>
var images = ['001.png', '002.png', '003.png', '004.png', '005.png', '006.png', '007.png', '008.png', '009.png', '011.png', '012.png', '013.png', '014.png', '015.png', '016.png', '017.png', '018.png', '019.png', '020.png', '021.png', '022.png', '023.png', '024.png', '025.png', '026.png'];
var index = 0;
var fade_in = one;
var fade_out = two;
fade_in = fade_out;
setTimeout(fade, 4500);
fade();
</script>
</body></html>
28,365
5,506
Johnny, have you tried BossPaper?
ronaldcs
Feb 11, 2011
The problem lies in setting the .src property too soon before the animation ends. Try this:
<html><head>
<style>
body {
margin: 0;
height: 442px;
width: 320px;
img {
position: absolute;
width: 320px;
height: auto;
img.fade-out {
opacity: 0;
img.fade-in {
opacity: 1;
</style>
<img id="one"/>
<img id="two"/>
<script>
var images = ['img01.png', 'img02.png', 'img03.png', 'img04.png', 'img05.png'];
var index = 0;
var toggle = 0;
var fade_one = one;
var fade_two = two;
var fade_toggle = ['out', 'in'];
fade_one.src = images[index];
fade_two.src = images[index];
fade_one.className = 'fade-' + fade_toggle[toggle];
toggle = (toggle + 1) % fade_toggle.length;
fade_two.className = 'fade-' + fade_toggle[toggle];
setTimeout(function () { if(fade_one.className == 'fade-out') { fade_one.src = images[index]; } else { fade_two.src = images[index]; } }, 2000);
fade();
</script>
</body></html>
Apr 7, 2011
Need help with saurik theme!
Okay so i found out how to change the saurik wallpapers to the ones i want but when ever it goes in for the transition the photo coming up goes horizontally and then goes vertical(the way it should be) im not sure how to fix that? Any help?
28,365
5,506
You can add the dock to your theme or to the system folder.
Your theme:
System Folder:
First backup the original dock. Then place the dock in System > Library > CoreServices > SpringBoard.app
28,365
5,506
Can you post a screenshot?
28,365
5,506
This happens because iOS 4 has a different size dock because of the multitasking popup. Try resizing the dock image heights from 90 to 45.
XNivekkX
Jan 5, 2012
Hello i have 13 pictures and followed your html and ... the only pictures i get is a Blue square with a question mark ... i see it fade but it still gives me an other question mark
Never mind found out the problem the file was in PNG (capital letters) when it was supposed to be in non capital letters
