help with pictures
juantamad
May 27, 2012
Makati
I have pictures saved on my Ipod touch. My computer who has the back up has already retired and I no longer have access to the back up pictures. If I sync my Ipod to another machine will I lose my pictures? please help. TIA.
owieh
Jul 15, 2010
481
60
Sheffield, UK
twitter.com
When you say "saved" you mean you synchronised them from the computer to you iPod touch? If so, you'd lose those of you sync to another computer. If you took the photos with your device you should not lose them as iTunes should just back it up.
If you are still worried, I suggest you download iExplorer from macroplant(dot)com. It's free and works for both Windows and Mac.
After installing, connect your device; when iTunes opens, just close it. Open iExplorer then on the left pane you'd see folders. The photos should be there, you could just drag the folder to your Desktop to copy them off your device.
Hope this helps.
