help with 'remote' app
Smokey
Sep 17, 2008
93
I just downloaded the app and when I try to find my iTunes library (and yes I'm on wifi on my iPhone...but not on my computer, that's regular broadband) nothing shows up in the devices list
dturner
Dec 15, 2007
5,725
Louisville, Ky.
I do believe you have to be on a wifi network. So if the computer isn't on wifi, iTunes won't be recognized.
Smokey
Sep 17, 2008
93
frack my life lol
oakie
Oct 18, 2008
46
Las Vegas
www.revtarded.com
nope. the computer doesn't have to be connected via wifi... it just has to be connected to the same network. if you have a wifi router, it can be connected via lan cable.
so in the OP's case, connect your modem to your wifi router's input, then attach the computer to one of the lan ports. this will not only put the computer within the same network, but will also allow anything connected via wifi to have direct internet access via the wwan... like your iPhone.
unless of course you have no wifi router and have the computer connected directly to a modem and your iPhone is connected via wifi to your neighbor's unsecured wwan.
