Help with SIM tray
samm
Oct 6, 2007
help me. my sim tray is not coming out. my sim is working but i have to change the sim and tray is not coming out on pressing into hole.
what to do now and how to?
Jun 27, 2007
198
You need to use a paperclip and press down on the hole, make sure you are pressing down fairly hard
jjvaldez
Jul 3, 2007
2,615
35
Salinas, Ca
make sure to keep the paper clip straight or you will not hit that little thing that is in the whole and the tray wont come up..
samm
Oct 6, 2007
help me
I'm pressing thebutton, but it is soft and tray not coming out, it got stuck, but sim is working fine. as it is also in right state.
then what to do?
