Help...
Oct 28, 2007
24
Ok... I am really good with iPhone and with iPods... Jaolbreaking them.
But today... was a really had day for me...
My cousin comes up to me and asks me to upgrade to 1.1.2 on his iPhone(Jailbroken, not sure about unlocked).
I tell il finish in about 30 minutes.
I start by installing Oktoprep, and then upgrading to 1.1.2.
It finishes and... it starts on the Slide for emergency screen with the connect the iTunes screen. Them I plug it in to iTunes and it makes me sign up for the data plan (My cousin doesn't want the data plan... to much money).I canceland unplug the iPhone. Then, I try to jailbreak it while its on the dialpad. It finishes and I reboot. Same screen... Then I try to do the *#301# thing to go into setting... it doesn't work...
Then I restore back to 1.1.1, and I jailbroke it and stuff... but now it won't activate and I can't call...
This has happened to me before, with my brothers iPhone, it fixed when I upgraded to 1.1.2 (He has the data plan).
So... I'm stuck with his iPhone, and I need to get it back up again... Help?
enigmanic
Jun 27, 2007
513
The reason why you cant make any phone calls is because the baseband is still at 1.1.2. You need to revirginize/downgrade the baseband to 1.1.1. Just check out this website for all your tutorial needs:
http://iPhone.unlock.no/
Oct 28, 2007
24
Ok... wait...
Im at 1.1.1 everything it working fine, but the phone isn't working... so i have to...
1. Downgrade the Baseband to the 1.1.1 one (Since, i upgraded to 1.1.2) with the BB downgrader (1.1.2) right?
2. Let it do its stuff, and then restore again to 1.1.1 (Please correct me if i am wrong)
3.Once done... just jailbreak and go on as normal?
Sorry... im not that great with iPhone stuff... im really just great with iPod touchs
enigmanic
Jun 27, 2007
513
Ok... wait...
Yes on all three. Good luck!
enigmanic
Jun 27, 2007
513
Ok... wait again...
Im on 1.1.1 right now... so, do i use the BB Downgrader(1.1.2) when im on 1.1.2 or when im on 1.1.1?
Yes, you would use BB Downgrader after downgrading back to 1.1.1. First, make sure your modem version is 04.02.13_G by going Settings → General → About. If it is, then you're safe to proceed with BB Downgrader.
Just follow the instructions closely on that website and you should be fine. If you mess up, just start over.
6,682
49
If you are jailbreaking his phone on your PC, part of the problem is that there is no profile to "install" that will be recognized.
I recently went through this and this is what I did:
1)Had to restore 1.1.2
2)downgraded to 1.1.1. after it was done, I restored my profile. If I haddn't, the phone would have stayed in emergency mode. My profile allowed me to use the phone minus calling. I never was able to Do the #*3blahblahblah method. I'm sure it works, I was just never able to do it.
3) Jailbroke 1.1.1 and installed oktoprep
3) updated back to 1.1.2 and then ran the windows.bat
4) sync'd to get all my profile info and all media
5) installed my apps.
Oct 28, 2007
24
Oh...Oh Oh!
When i restored back to 1.1.1, i was able to make a profile, so now when i upgrade i will continue on as normal...hopefully...
Oct 28, 2007
24
Ok... now all i need is his SIM card... (He took it because he needed a phone for the next day)
Its still on the Slide for emergency screen, is that normal when you upgrade?
Also... can i enter my brothers SIM card? Will it change anything?
Oct 28, 2007
24
Update:
I upgraded to 1.1.2 and the same thing happened... the activation screen...
Downgrading right now... il update again...
Oct 28, 2007
24
Theres no BB Downgrader... Wah!
http://i.unlock.no/ doesn't have it!
enigmanic
Jun 27, 2007
513
Yes I did...
Can you check if you have it?
Yep, just checked and it's listed under the "Unlocking Tools" category, called "Baseband Downgrader". If you don't see an "Unlocking Tools" category, that means you didn't add the source correctly. Try adding it again...the URL is case-sensitive, so make sure the "i" in http://i.unlock.no is lower case (the iPhone tends to automatically capitalize it).
Oct 28, 2007
24
I thought it was called BB Downgrade (1.1.2)? Exactly. I guess just for short.
Are you SURE this is right?
enigmanic
Jun 27, 2007
513
Hmmm..you're right...this seems to be for 1.0.2 baseband. I clicked on "more info" and it says it will downgrade the baseband to 03.14.08, which is for 1.0.2 phones. BB Downgrader for 1.1.2 was definitely there just a week ago. I'm sure there are other installer sources out there that have BB Downgrader, but I don't know any off hand. If I find out, I'll let you know.
Oct 28, 2007
24
Thank you so much man!
Il look around to so you don't have to do all the work...
