helppp! iPhone stuck
NeO2
Nov 18, 2007
somebody please help meee!
My phone is unlocked...i bought it that way...i live outside of the US....i started to install a lot of apps...so the phone got stuck...and now it get's stuck in the menu...if i restore it with i tunes...will this brick my iPhone? how can i uninstall the apps without the iPhone being turned on?
NeO2
Nov 18, 2007
it's ok...i fixed it...:-D
kenn11
Nov 13, 2007
how did u fix it tell me =/
NeO2
Nov 18, 2007
i went to Apple...and they fixed it by installing new software...if you are in the usa and u you are using AT&T i suppose you can install new software...if this is true for you...then just turn off your iPhone and hold the Home button while plugging it in your PC...iTunes will show that your iPhone is in...recovery mode or something...sorry i can't remember...than...you can install the newest software from Apple..again...i don't know if it's free because i don't live in the USA......i hope this helps...
NeO2
NeO2
Nov 18, 2007
no problem...if you're having other problems...just PM me...
