Hey plzz help me :(:(:(
Jul 4, 2009
9
i am buying an iPhone 3g MB500ZP/A iPhone 3G White,16GB thats is the serial number for it so it is a chinese spec iPhone from hongkong..i am worrying that the uk simcard might not fit in the sim slot tray? please any1 that knows an answer please reply.. thnx
28,365
5,507
Where did you order it from?
Ramesh
Jul 12, 2007
4,571
Irvine, Ca.
That model number comes up as an unlocked Hong Kong version.
Jul 4, 2009
9
that wasn't the question i asked though..i asked will my uk sim card fit into a hongkong/chinese sim slot tray.?
Ramesh
Jul 12, 2007
4,571
Irvine, Ca.
Wow. There's only one sim card tray "design". Yes. The iPhone doesn't have multiple sim card trays. Sim card = sim card.
Use google if you need more explanation.
Jul 4, 2009
9
sorry did i sound nasty there if i did sorry m8..Are you sure m8 theres only one size of iPhone slot..can you give me any proof or what do i type into google..
28,365
5,507
Sweet! Your SIM will fit in it, don't worry about that. They are universal, there is only one size. Factory unlocked phones are nice, I would love to get my hands on one. That way you don't have to worry about doing the software unlocks and never run the risk of them locking on you.
Jul 4, 2009
9
just one more thing if its a hong kong iPhone why is it a chinese spec..
dturner
Dec 15, 2007
5,725
Louisville, Ky.
We understand you have a ton of emotion going on and want to be sure before you get the phone. Rest assured there is only one sim card tray and your sim will fit.
Hope you enjoy the phone as much as we do. Let us know when you get it.:)
Bitewound
Sep 7, 2007
1,297
134
Biteyland NYC
I have used UK sim cards in my US phones- there is only one size sim card
