Hi everybody
Heba
Oct 28, 2012
24
My i pad didn't make update for apps since yesterday.
Anybody know why?
Sent using iCafe app
MoneyMaker79
Dec 15, 2008
5,386
340
30
Pensacola, FL
Are you saying it did not inform you of updates since yesterday? Sometimes that can happen. I have trouble getting updates for my iPhone, so I just open the App Store every now and then to check for updates. You could also check for updates using iTunes.
Heba
Oct 28, 2012
24
No my ipad notice me that there is update but didn't make it.
Heba
Oct 28, 2012
24
I will try to make update on iTunes.
Thanks a lot your great.
A333West
Feb 7, 2013
22
I've been having that issue too-- freezing during app updates. I actually deleted a lot of the apps that I don't use often because this was so annoying
MrMike6by9
Nov 16, 2008
1,482
119
72
Maryland, USA
You might want to clear some of your inactive apps to free up memory space before trying to perform your updates. You might want to also consider doing only a few at a time instead of "update all". Some of my astronomy apps are huge, for example, so I'll often do those one at a time.
YMMV
  • Like
Reactions: Heba
