what you want to do is install a LOADER (there are a few available from your INSTALLER ap, or install the DOCK application with the sunburst in the bottom right. Loader applications are like a folder for all your apps, you click on the loader icon and all your applications (hidden or not) will be in this application. The DOCK Sunburst application is just a quicker way to access these (drag out from corner and flip through every application on your phone, you can also access your customize application to make these applications viewable again if you need to)
I hope this helps
