Hiddenapps: Disable iAds and Hide Stock Apps
Kadelic
Jan 4, 2010
4,957
1,609
Dallas, TX
Update: It turns out the Stocks app has been replaced by a "POOF" icon in the folder I had it stashed in. Not really my idea of hiding an app if it's just replaced with an arbitrary icon.
I would have just edited my previous post but the eiC app doesn't allow attaching pics when editing posts.
EDIT: Using the "Unhide all Apps" function didn't unhide the apps I hid using this app. The respring caused the first "dark respring" I've had in a few weeks. I'm not sure how this app got through to the App Store. I've deleted the app and did a hard reset and the Stocks app is still "poof." It doesn't show up in Spotlight either.
Kadelic
Jan 4, 2010
4,957
1,609
Dallas, TX
So how do I get my hidden app back? I never use it but I can't get rid of that "poof" either.
EDIT: I was finally able to delete the poof and the hidden app came back after a respring. :)
RoofMonkey
Jun 21, 2010
8,913
1,979
If you get it to work, you have to reapply it after every respring or reboot.
'Fail'
Sent using iCafe app
