Hide icons IOS 8
yanko
Dec 29, 2014
I can't find a tweak that hides app icons from SB in ios 8. I have tried:
poof - doesn't work. Most apps don't show up in the list.
appro - seems good but makes hidden apps completely inaccessible even when appro is disabled.
The best I've been able to do so far is put all icons I want to hide in a folder and make the folder invisible. This is not a great solution, because you can still open the folder.
Any ideas?
Many thanks!
Yanko
5,578
Any ideas?
Many thanks!
Yanko
Springtomize 3.
yanko
Dec 29, 2014
The problem with Springtomize 3 is that running apps with hidden icons are hidden from the app switcher. Consequently I can't switch between running apps with hidden icons. This wasn't the case with the old SBSettings. Are there other apps for hiding icons?
5,578
You could use Appro. You just need to add them to the "Hidden Whitelist" if you want them to be accessible when hidden.
