Home screen background
Nov 10, 2011
Can anyone tell me how I can reduce the size of pics I use for wallpaper? Would also like to change the folder color,
Sent using iCafe app
Dec 10, 2009
2,589
1,337
51
Clarksburg, WV
As far as I know, you cannot change the size of stock iOS wallpapers.
In the Settings menu under "Brightness and Wallpapers" selecting "Wallpapers" will bring up a sub menu where you can choose something from your camera roll or photostream.
Whatever you select will come on screen with the option to "Move and Scale":
Move image with your finger.
Scale by pinching in or out with two fingers.
Hit the "set" button, and it will ask where you want to assign it.
Lockscreen, homepage or both....
Nov 10, 2011
Thanks for the reply. When I try to pinch it to make it smaller, it goes right back to the size it was. Moving it does the same thing. I'm really disappointed more and more as I discover things I could do before and can't do now.
Nov 10, 2011
Some are pictures I have taken and are in camera roll and some of them have been saved from websites. Nothing works to resize them like ios6 allowed me to do.
jaydoc1
Sep 23, 2007
608
Having the same issue scaling with my iPad 3 and 4S on ios 7 as well. Just snaps back to the original size if I can get it to scale at all.
jalalawi
Apr 23, 2011
246
I don't have problem with iOS 6 but I have it now with iOS 7 because I am using same photo with iOS 6 and it was fit to lock screen but with the iOS 7 same photo is not fit and tried to scale it but still not fit!
Nov 10, 2011
Thanks Snowtrooper but that isn't resizing the picture. It's cropping out part of the picture. I would like to keep the whole picture and just resize it.
Dec 10, 2009
2,589
1,337
51
Clarksburg, WV
OK, sorry.
Just re-read your OP. Never been able to scale down, AFAIK.
You will have to look outside of the stock iOS ecosystem to accomplish that.
You will of course be reducing the resolution.....
