Honest opinion
guesswhatman
Jun 28, 2007
27
i tried the iPhone in the store and loved it....but i have a laptop and after awhile i hate using my finger on the pad and prefer to use a mouse. would i not like the iPhone?
dwp1975
Jul 4, 2007
561
45
Rockville, MD
I am the same way, I detest the touchpad, I rather use the little rubber erasure joystick, but it will not make you dislike the iPhone at all!:sick:
jhawk
Jul 15, 2007
22
I'm the same way, I don't like using the touch pad on my laptop either. I was a little skeptical of the touch screen for typing. I am coming from a Palm Treo and text messaging/typing was very easy, on my iPHONE, it's just as easy, if not easier. It took me a couple days to get used to it but it is great, no complaints here.
GP78
Jul 2, 2007
23
NJ, USA
The touch screen on the iPhone isn't like the trackpad on your laptop. You don't have to constantly keep your finger on it to navigate. Taps and swipes are all you need. It's not a constant input, because you're not moving a cursor... your finger is the cursor. :)
But... go try it again at an Apple Store. Play with it some more. It's not like you're gonna be using it as a laptop replacement. (However, If you're thinking of using it as a mini-laptop (to replace carrying around your real laptop) then it probably isn't the phone for you. You'll probably do better with a Windows Mobile 5 or 6 phone. Something like the AT&T 8525 or wait a month for the upcoming AT&T 8925.)
DRabbit
Jul 2, 2007
383
I detest windows-based touchpads on laptops. The one on my MacBook is marvelous (if you've never used one, it also has a sort-of multi-touch technology)...
But that said, I don't find using the iPhone at ALL like using a touchpad... it's really a very different experience.
