How big can the battery image be?
H
Hayesimus
Guest
The one you see on the lock screen when it is plugged into a charger. I was thinking of something that would be cool that I want to do but I don't know if it would work unless I can increase the height and width of the image. So is that possible? or is that current dimension the only one that will work?!
H
Hayesimus
Guest
B to the UMP
Oct 4, 2007
537
29
San Francisco
I don't know the exact dimensions, but i have seen other battery images that are higher and have a longer width than the stock battery image.
H
Hayesimus
Guest
See I'm wondering if you can create a more FITTING image that leaves less empty space around the place.
Oct 4, 2007
537
29
San Francisco
This has nothing to do with your question, but I think that this is one of the best battery images that I have seen. -Link-
H
Hayesimus
Guest
Haha. that is great. I like how it says in about 30 minutes lol. The one I'm using right now is the Duracel battery. Or wait... it was... now its not... hmmm... that's odd... now its the stock one... i'm displeased...
