How can I assign actual songs as ringtone for contacts
verwon
Jul 29, 2011
1,015
121
Seattle
You'll have to either buy it as a ringtone, or create your own. You can create them in iTunes. They have to be in m4r format.
Rugaby
Feb 18, 2011
7,122
1,172
Washington state
When you do have a ringtone imported or just want to assign a certain time to a contact here is how.
Click on contacts
Select your person
Select edit
Select ringtone and assign
Btw that number is disconnected. Why I chose it.
RoofMonkey
Jun 21, 2010
8,913
1,979
Get a program called iRinger. IRinger.net is their page. This program let's you make a ringtone in 3 steps from any song you have on your computer.
It will even import it directly to iTunes for you.
Marx
Jul 28, 2009
you can create ringtones for free without any software using ringer.org, just make sure to choose M4R format there
and then export them to your phone via iTunes
bams50
Nov 23, 2007
277
33
Or you can just get a free app called Ringtone Converter. Works great with whatever song you want, and is so simple even I can do it!:)
