How can I have scorlling screen ?
tommy
Jan 4, 2008
I have more applications then can be seen by the main screen. I saw someone with an iPhone who just slides the main screen sideways and can see his other applications. How can I do that ?
THank you in advance.
Griffinaz
Oct 5, 2007
1,046
Phoenix, Arizona
Version 1.1.2 has this built into it. If you have an earlier version (1.0.2 or 1.1.1) you will need to do as meiPhones_brill said and install Summerboard. It is an add on program that allows scrolling of the desktop icons.
timtim
Feb 13, 2008
Summerboard
I am using 1.0.2, have installed apptapp but it lists Summerboard 3 and 3.1 only.
How can i get Summerboard or any other app so that the springboard can be extended
hpuk
Jan 2, 2008
60
London
update to 1.1.3 and use the new easy jailbrake! it took me 5 mins!
