How can I print text messages on iPhone?
CodalySally
Sep 4, 2013
Hello, I have a question, does anybody knows that how to print out the text messages on my iPhone 4s? I need to do that! Please help!
JON35Y
Oct 16, 2012
87
You could copy and paste them into an email? Or just take a photo of your screen and email that to yourself. Other than that I'm not sure?!
RoofMonkey
Jun 21, 2010
8,924
1,984
If you happen to be jailbroken there is a tweak in cydia that let's you save messages to a PDF. If not, you will have to do screen shots or a lot of copy & pasting to an email sadly.
Grant Leadbetter
Sep 16, 2013
Yes, you can take screen shots and print them. You can also try a third party program. I use decipher text message to save and print out my work sms messages for safe keeping. It prints them out with the bubbles just like on the phone itself. :)
CodalySally
Sep 4, 2013
Take screen shots? It maybe a good idea, I will give it a try!
RBNetEngr
Jun 17, 2013
171
27
I have an HP printer and I set up HP's free Mobile Printing:
http://www.hp.com/united-states/campaigns/mobility/m/
You can go into Messages, open the SMS or iMessage thread you want to print. Then, choose Edit, select the conversation item(a), then select Forward and send them to the email address associated with your printer, and they should print.
I have not tried it.
-rb
Stitching screenshots? You guys are making this way too difficult. Just use a PC/Mac app like Diskaid. It lets you view, back up and print your texts.
  • Like
Reactions: RoofMonkey
But disk aid is $29 and the app they mentioned is Free. LOL
The iOS Stitch It app for printing screenshots from your phone? There are better free (or cheaper than Diskaid at least) alternatives that wouldn't use as much ink. I think you can do a trial for Diskaid. But that's just one app example. It's is a very powerful program. I bought it years ago for less than that. I use it for modifying system files when jailbroken.
  • Like
ZR_Yancy
Jul 11, 2008
3,982
737
Why don't you just email the text conversation to yourself then print the email.
Open the conversation
Press and hold on a line of text until the menu appears.
Select "more" and select the lines you want included in the email then select the forward icon at the bottom right corner
Finally, send it to yourself and print the email.
If you have AirPrint, you can skip the email step and just copy the body of the email, open your notes app, paste it and finally print.
Ledsteplin
Oct 29, 2013
4,853
1,000
67
Florence, AL
That only works if the email address is not in your own contact. If the email address is in your contact, it will just send it to you by iMessage. I created a second contact for myself with only an email address. No number. So I forward the message to that email, and it worked. It actually sent it to me by iMessage and to the email address. I use a different name on the 2nd contact. Instead of my name, I use iCloud. That's the email address I put on it.
ZR_Yancy
Jul 11, 2008
3,982
737
When sending the email to yourself, instead of using the + icon to add the email, just type the email.
