How can I see what app my iPhone is using to sync contacts?
chirojh
Aug 15, 2007
I wanted to know where my iPhone is syncing my contacts and calendar to. I look under outlook but it is not there. Also is there a way to sync the contacts from my phone that is already saved to the phone to outlook.
NMprofessional
Aug 1, 2007
45
Rochester NY
To see where iTunes is syncing your contacts (iTunes on a PC):
> Open iTunes.
> Place your iPhone in the cradle.
> Select your iPhone's name.
> Click the Info tab.
> Change it to "Sunc contacts from: Outlook" if you want Outlook to be you contact sync.
